Thank you for your warm welcome greetings, Hannes and I was able to successfully swap the both original headlamps to Purevision with the help from ny,newyork. I'd like to mention his help once again here and truly appreciate it.
Well, the process of installation is kind of simple; you take off the Talisman's front bumper, loosen some screws for the lamps and replicate them. as you mentioned on the post, the xenon lamp has the same connector with the PH1 Purevision (not PH2!) which means, super easy to wire the lamp!
after the installation, you will encounter 3 problems like I had;
1. The passing light function will not work properly.
2. During the high beams turned on, the light will be intermittently on and off for very short time like micro seconds.
3. Idk if it apply to you but in Korea, if your Talisman has the xenon lamp, that means you don't have "Auto Leveling" function. (Sorry, I dunno what you guys call it.  I'm mentioning the device that automatically adjusts the height of the light emitted by the headlamp.)
You can simply solve the problem no. 1 and 2 easily using OBD connector of version 1.5 and a Windows program called "DDT4all". However, the problem No.3 needs to order an extra part to install on your vehicle and flash with a professional tool called "Clip". I'd love to help you if you're interested in and planning to replace it. let me know if you're. I owe this community something. I'd like to help if I can .
