I have recently bought SanDisk Ultra Flair 64GB USB 3.0 for the map updates only to find that it needs to be formatted in FAT32.
Windows 11 system tools cannot format paritions larger than 32GB in FAT32 system so I had to manually partition it and format it from the administrators command line.
Only then it was useable by the Renault tool.
So if you plan to use it only for the maps update - to spare yourself the technicals and/or trouble just buy the 32GB one.
Best regards
Beiträge von LukasEV
Kurz ein Zwischenstand,
was auch immer da installiert wurde, es ist keine neue Version und auch sonst hat sich nichts geändert.
As per your photo the updated component was IVC which is responsible for connectivity/telematics, as per the Alliance Update tool manual at least.
Lukas -
I have my Software ID documentation and had collected informations and pics, wich shows the EasyLink Software ID. Not all in EasyLink installed versions where available in R-Box. Some one where only FOTA or ex works.
I never said that EasyLink ID can be downloaded on my PC. New EasyLink Software is available by FOTA or by R-Box in garages. The latest one is 38683 in R-Box only.
I have in my documentation a information "Werkstatt" (R-Box) or "ota" (FOTA) or "Werk" (ex works).
Hello Udo,
my answer wasn't directed at you I was just surprised and curious that you can find documentation on r-box/alliance upd@te etc. online with Google and 5 minutes of work.
Also I do not work at Renault and I also share your (and not only your) feelings about unability to fix things by them.
Probably misscommunication from my side.
Greetings
Lukas -
Funny thing that you can download it (Alliance update) for yourself but it still will be useless without R-Box and the Token.
PO After-sales CCS1 (renault.com)
PLUGNCONNECT docs
Lukas -
Die 39788 kann man ja auch auf 33608 downgraden.
39788 finally made itself into the Bosch webpage, it suggests it is quite old (December, 2021). 33608 is probably newer (because it is still not on the webpage).
I've had quite big problems with 39788 that were fixed with 33608.Grüße, Lukas
an aI c
Konntest Du oder kannst Du den Motor Sound gar nicht einstellen?
Hallo Sascha,
Ich kann es ändern.
Lukas -
Hello Udo,
There's no way of telling which build is really newer in this particular case.
OTA 39788 was released to the public later than 33608 to the garage but on the other hand it's usually that way that OTA is tested for much longer period of time than the garage builds.
I cannot upgrade from 33608 to 39788 that's for sure. And I'm kind of happier with 33608 because with 39788 I've had more bugs than usual.
Lukas
OTA 39788 here (RFC), no changes to the BOSE
Today at the workshop they upgraded it from 39788 to 33608, still no changes to the BOSE.
Lukas
Hi Lukas
Der Thread geht um das Easy Link im Phase2 und dem dazugehörenden OTA der Updates und indirekt um das Bose Problem mit der Soundspeicherung .
Hallo LG,
I'm sorry for the detour, I can only confirm that with OTA 39788 it is still not fixed for the Phase 2 for me.
Lukas
