ich in Excell:
in diese Aufstellung klicken und Cursor nach rechts bewegen um ganzen Tabelleninhalt zu sehen
Wunsch | ESU name | Untername | Aktion | Unteraktion | Feld | IST | SOLL |
ändern in | |||||||
Tagfahrlich hinten ein | EMM | USM_CMF_xxx | Lichter | Lichter Configuration | E_B_DRL_withTail | 0 | 1 |
WelcomeSequenz | Audio[$13] | RadNav v2.3 | Configuration | ECU Configuration II | welcome sequenz | Initiale | RS…GT… |
Außentemp.im Tacho | Tableau de bord [$51] | Cluster_15-40_v3.30.02 | Ecrans Configuration | Conf Prestation | External_Temperature_CF | External Temp. Mensurement and Display | |
PDC im Tacho | Tableau de bord [$51] | Cluster_15-40_v3.30.02 | Ecrans Configuration | Conf Prestation IHM | UPAMMI_CF | without | with front and rear UPA MMI |
Tacho max.260 km/h | Tableau de bord [$51] | Cluster_15-40_v3.00 | Ecrans Configuration | Conf Prestation VEH | SpeedSCaleType_CF | 240 km/h | 260 km/h |
Nachwischer | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | FrontWIPER | FrontWiper-Config | FRONT_DROP_WIPE_CF | true | false |
Komfort-Blinker | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | Flashers | Flasher-config | T_PULSE_CF | true | false |
Blinken bei bremsen/Unfall | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | Flashers | Flasher-config | HZARD_WITH……. | true | false |
ETA (nur Espace) Fußwedelsensor | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | LinII | LinII-Configuration | EASY_TRUNK_ACCESS_ECU_CF | false | true |
Gangwechselanzeige Automatic | Tableau de bord [$51] | Cluster_15-40_v3.30.02 | Ecrans Configuration | Conf Prestation VEH | GearBoxType_CF | xxx | entsprechend auswählen |
Start&Stop eliminieren | EMM | USM_CMF1_Sailing_B4 | BatteryGauge | BatteryGauge Configuration | E_B_STOPSTARTInhibit | No Value | 1 |
Anschnallgurt Warnung eliminieren | Tableau de bord [$51] | Cluster_15-40_v3.30.02 | Ecrans Configuration | Conf Prestation VEH | Front SBR | not inhibited | inhibited |
Müdigkeitserkennung | Audio[$13] | RadNav v2.3 | Configuration | RadNav Configuration 1.1 | Unstable trajectory alert | absent | present |
Tagfahrlicht aus bei Blinken | EMM | USM_CMF_xxx | Lichter | Lichter Configuration | E_B_DRLinhibitByFlasher | 0 | 1 |
Dach öffnen unter 0° C | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | Defroster | Defroster-Configuration | OPENABLE_ROOF_CF | false | true |
Spurwarner(LDW) km/h Bereich | FCAM | FrontCamera2014_ECU_3.0 | Diagnostic | 4_Camera_Configuration | LDW MIN SPEED ACTIV 2x | km/h eintragen | |
Pedal(Kupplung od.Bremse)beim Starten erforderlich | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | FAL | FAL-Configuration | START_WITH_PEDAL_PRESS_CF | false | true |
Frontblinker mit Birne ? | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | HWDiagnosticManagement | HWDiagnosticManagement-Configuration | FRONTflashers_withBULB | false | or true |
auch Frontblinker mit Birne ? | UCBIC/BFR[$26] | C1A_BCM_DDT_9 | HWDiagnostic | HWDiagnostic-Configuration | FRONTflashers_withBULB | false | or true |
